Plesk switches to Power User view after installing a license
Created:
2017-07-20 15:08:36 UTC
Modified:
2017-08-16 16:52:55 UTC
Have more questions?
Submit a request
  • Plesk Onyx for Linux
After applying the license, Plesk changes the view in case the value described in central.plesk.com does not match the current one in Plesk. It is not impossible to override this option.
Currently it is expected behavior, however it is considered as a point for improvement: PPM-2137
As a workaround:
1. Connect to Plesk Panel
2. Navigate to Tools & Settings > Interface Management
3. Select "Service Provider view" and click OK
Alternatively, l ogin to the server over SSH and disable the Power User mode via CLI:
# /usr/local/psa/bin/poweruser --off
