Plesk does not check for updates automatically despite the option Plesk > Tools & Settings > Update and Upgrade Settings > Automatically install Plesk updates (Recommended) is enabled.
Plesk license is not automatically renewed.
In
/var/log/cron
the following errors can be found:CONFIG_TEXT: Jul 7 10:01:01 ip-0-0-0-0 anacron[26504]: Job `cron.daily' locked by another anacron - skipping
Jul 7 10:01:01 ip-0-0-0-0 anacron[26504]: Job `cron.weekly' locked by another anacron - skipping
Cron processes got stuck.
Connect to the server via SSH
Find IDs of stuck cron processes:
# ps aux | grep cron
root 1233 0.0 0.0 19064 968 ? Ss 2016 0:00 /usr/sbin/anacron -s
root 1608 0.0 0.0 9208 1300 ? SN 2016 0:00 /bin/bash /usr/bin/run-parts /etc/cron.daily -
Finish them using the following command:
# kill -9 1233 1608
Restart crond service:
# service crond restart
