Unable to start mariadb: Can't read dir of '/etc/my.cnf.'
Created:
2017-01-19 05:23:29 UTC
Modified:
2017-08-08 13:15:27 UTC
1
Have more questions?
Submit a request
Issue Symptoms
Unable to start mariadb service:
# systemctl status mariadb.service
● mariadb.service - MariaDB database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2017-01-19 11:58:18 +07; 9s ago
Process: 3569 ExecStartPost=/usr/libexec/mariadb-wait-ready $MAINPID (code=exited, status=1/FAILURE)
Process: 3568 ExecStart=/usr/bin/mysqld_safe --basedir=/usr (code=exited, status=0/SUCCESS)
Process: 3540 ExecStartPre=/usr/libexec/mariadb-prepare-db-dir %n (code=exited, status=0/SUCCESS)
Main PID: 3568 (code=exited, status=0/SUCCESS)
Jan 19 11:58:17 server_name mysqld_safe[3568]: Fatal error in defaults handling. Program aborted
Jan 19 11:58:17 server_name mysqld_safe[3568]: [74B blob data]
Program aborted
Jan 19 11:58:17 server_name mysqld_safe[3568]: 170119 11:58:17 mysqld_safe Logging to '/var/lib/mysql/server_name.err'.
Starting mysqld daemon with databases from /var/lib/mysql
Jan 19 11:58:17 server_name mysqld_safe[3568]: 170119 11:58:17 mysqld_safe mysqld from pid file /var/lib/mysql/server_name.pid ended
Following error can be found in /var/lib/mysql/server_name.err:
170119 11:52:41 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
^G/usr/libexec/mysqld: Can't read dir of '/etc/my.cnf.' (Errcode: 2)
170119 11:52:41 mysqld_safe mysqld from pid file /var/lib/mysql/server_name.pid ended
Conditions
Under investigation.
Resolution:
Add one more line in the end of /etc/my.cnf:
# cat /etc/my.cnf
!includedir /etc/my.cnf.d
# add new line here
