Plesk for Windows
Plesk for Linux
kb: how-to
ABT: Group B
- Plesk for Windows
How to check hardware usage (CPU, Memory, disk I/O) consumed by a process of a website?
Go to Tools & Settings > Process List (under Assistance and Troubleshooting).
Note: If Process List is not available, make sure that the Repair Kit Plesk Extension is installed and enabled.
Click Domains only to exclude system processes.
Turn on Auto-update of resource usage to track processes in real time.
Note: To sort the processes by CPU usage, Memory usage, Disk I/O (read), Disk I/O (write), click on the corresponding column.
3 comments
Any alternative to this that provide historical graph?
Hi @Sharul Hafiz!
While there is no easy way to do that with top utility, there is an alternative: use atop utility.
Check the following links for additional details:
https://support.plesk.com/hc/en-us/articles/115001935165-How-to-monitor-usage-of-system-resources-in-a-period-of-time-using-atop-
https://haydenjames.io/use-atop-linux-server-performance-analysis/
Hi.
How can I see the CPU or RAM usage by domain, for example: the last hour or the last month RAM and CPU? I would like to know which domains use the most resources.
Regards.
