- Plesk for Windows
Domain creation in Plesk fails with the following error:
PLESK_ERROR: websrvmng failed: Application pool 'example.com(domain)(2.0)(pool)' does not exist In IIS7NativeProvider module Exception type: System.Exception IISApplicationPools.get_pool(IISApplicationPools* , unique_ptr >* , basic_string\,std::allocator >* poolName) at setAppPoolIdentity(example.com(domain)(2.0)(pool), IWPD_862(johndoe))(WebServerAdapter::setAppPoolIdentity line 3209) at addAppPool(example.com(domain)(2.0)(pool))(WebServerManager::addAppPool line 2048) at execute console command --add-app-pool(vconsoleapp::start line 122) at execute C:\plesk\admin\bin64\websrvmng --add-app-pool "--config=tmpDE30.tmp"(vconsoleapp::run line 139) (Error code 1)'
The domain may be created in Plesk without hosting;
The website with the same name and application pool already exists in IIS > Sites or IIS > Application pool;
An unsuccessful attempt to create or remove subscription with the same name previously
Go to Domains and check if the domain
example.com
exists. If it does, remove it. -
Connect to the server via RDP.
Go to IIS > Sites > example.com and remove the site.
Go to IIS > Application Pools > example.com(domain)(pool) and remove the application pool.
Create subscription
example.com
in Plesk again.
4 comments
Create the pool example.com(domain)(2.0)(pool) manually from IIS
Then from Plesk go to example.com >> Hosting Settings
@nashwan, could you share more details? Which exact issues did you have when applying this article?
The cause of behavior described in the article is that App Pool already exists in IIS.
This was very useful. Solved my issue. Thanks a lot.
Hi @Vyshak, glad to hear that.
