Unable to create subscription: Application pool does not exist
4 comments
    nashwan
    Create the pool example.com(domain)(2.0)(pool) manually from IIS
    Then from Plesk go to example.com >> Hosting Settings
    Ivan Postnikov
    @nashwan, could you share more details? Which exact issues did you have when applying this article?
    The cause of behavior described in the article is that App Pool already exists in IIS.
    Vyshak
    This was very useful. Solved my issue. Thanks a lot.
    Ivan Postnikov
    Hi @Vyshak, glad to hear that.
