The search speed is slow in Roundcube or Horde for Plesk
5 comments
    Jair Cueva Junior (Edited )
    I tried copy/past, and it didn't work.
    The mail_plugins part only work when it's out of the imap scope {}.
    In my case:
    mail_plugins = $mail_plugins fts fts_squat <<<< inside dovecot.conf
    Also, on de plugin part, i had to include this "vsz_limit = 20 GB" because the size of my mailboxes are bigger than 256MB which is the default limit.
    Now it's working.
    Ubuntu 14.04.5 - Plesk Onyx 17.5.3
    Bulat Tsydenov
    @Jair Cueva Junior,
    Hi!
    Thank you for pointing this out! However, I could not reproduce the issue you faced, I successfully applied the solution from this article. Can you please clarify the error message you get when applying the solution from this article?
    Jair Cueva Junior
    @Bulat Tsydenov,
    Hi!
    Actually I didn't see an error message, it was just the behavior that wasn't expected: When setting these things in /etc/dovecot/conf.d/99-fts.conf Dovecot just ignore 'em.
    In custom config files I can setup services, but not plugins which wasn't previously requested by /etc/dovecot/dovecot.conf.
    I don't know if it's a bug or limitation.
    My Dovecot is: plesk-dovecot 2.2.27-ubuntu14.04.17031716
    Is it possible/safe to upgrade dovecot to the native S.O version without breaking things?
    Bulat Tsydenov
    @Jair Cueva Junior,
    It is not recommended as the dovecot package shipped with Plesk is packaged by Plesk and has some customizations
    Jair Cueva Junior
    Ok!
