Postfix unable to start with error: open lock file /var/lib/postfix/master.lock: unable to set exclusive lock
Created:
2017-01-06 22:57:00 UTC
Modified:
2017-08-08 13:16:50 UTC
2
Have more questions?
Submit a request
  • Plesk for Linux
Issue Symptoms
Unable to start Postfix mail server, the following error occurs:
# systemctl status postfix
postfix.service - Postfix Mail Transport Agent
Loaded: loaded (/usr/lib/systemd/system/postfix.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2017-01-06 22:48:21 UTC; 4s ago
Process: 36797 ExecStart=/usr/sbin/postfix start (code=exited, status=1/FAILURE)
Process: 36794 ExecStartPre=/usr/libexec/postfix/chroot-update (code=exited, status=0/SUCCESS)
Process: 36792 ExecStartPre=/usr/libexec/postfix/aliasesdb (code=exited, status=0/SUCCESS)
Main PID: 13643 (code=killed, signal=TERM)
Jan 06 22:48:19 mail.plesk.com systemd[1]: Starting Postfix Mail Transport Agent...
Jan 06 22:48:19 mail.plesk.com postfix/master[36870]: fatal: open lock file /var/lib/postfix/master.lock: unable to set exclusive lock: Resource temporarily unavailable
Jan 06 22:48:20 mail.plesk.com postfix/master[36869]: fatal: daemon initialization failure
Jan 06 22:48:21 mail.plesk.com systemd[1]: postfix.service: control process exited, code=exited status=1
Jan 06 22:48:21 mail.plesk.com systemd[1]: Failed to start Postfix Mail Transport Agent.
Jan 06 22:48:21 mail.plesk.com systemd[1]: Unit postfix.service entered failed state.
Jan 06 22:48:21 mail.plesk.com systemd[1]: postfix.service failed.
Conditions
Hanged postfix process
1. Find and terminate hanged postfix processes using its PIDs:
# ps aux | grep postfix
# kill -9 PID
2. If /var/lib/postfix/master.lock file is present, remove it:
 # rm /var/lib/postfix/master.lock
3. Start Postfix:
# systemctl start postfix
