How to enable/disable TLS protocol versions in Plesk for Linux
27 comments
    Heinrich Krebs
    Is TLS1.3 now available for PLESK interface?
    Because Mozilla's recommendations, which are loaded into Obsidian, are
    server-side-tls-conf-4.0
    But there is already a
    server-side-tls-conf-5.0
    And the modern setting with this is not allowing anything below TLS1.3
    Marko D. (Edited )
    Ivan Postnikov: really not? If I check it with
    # plesk bin server_pref -s
    the answer is
    # ssl-protocols: TLSv1 TLSv1.1 TLSv1.2 TLSv1.3
    I beliefe, the SSL-It with modern option doensn't work, because ..
    ssl-ciphers: EECDH+AESGCM+AES128:EECDH+AESGCM+AES256:EECDH+CHACHA20:EDH+AESGCM+AES128:EDH+AESGCM+AES256:EDH+CHACHA20:EECDH+SHA256+AES128:EECDH+SHA384+AES256:EDH+SHA256+AES128:EDH+SHA256+AES256:EECDH+SHA1+AES128:EECDH+SHA1+AES256:EDH+SHA1+AES128:EDH+SHA1+AES256:EECDH+HIGH:EDH+HIGH:AESGCM+AES128:AESGCM+AES256:CHACHA20:SHA256+AES128:SHA256+AES256:SHA1+AES128:SHA1+AES256:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!3DES:!MD5:!PSK:!KRB5:!aECDH
    That means: TLS1 and 1.1. are still enabled and weak ciphers still present.
    Ivan Postnikov
    Hello @Pigr_46,
    In your case, TLS 1.1 should be disabled.
    Try this one:
    plesk bin server_pref -u -ssl-protocols 'TLSv1.2'
    Also, it might be needed to leave only strong ciphers enabled:
    plesk bin server_pref -u -ssl-ciphers 'ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256'
    Setting only modern ciphers may cause issues for visitors using old browsers.
    You may specify other ciphers using plesk bin server_pref utility. Please refer to the section '2.3 Use Secure Cipher Suites' in the following SSLlabs article.
    https://github.com/ssllabs/research/wiki/SSL-and-TLS-Deployment-Best-Practices
    lenala
    I want a PCI-DSS compliant server with TLS V1.3 and 1.2 only.
    I followed the guide but with some tuning since we run LiteSpeed servers :
    I edited following file : /etc/httpd/conf.d/ssl.conf and added at bottom :
    <IfModule LiteSpeed>
    SSLProtocol TLSv1.2 TLSv1.3
    SSLCipherSuite ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
    SSLHonorCipherOrder off SSLSessionTickets off
    SSLUseStapling On SSLStaplingCache "shmcb:logs/ssl_stapling(32768)"
    </IfModule>
    Then I ran plesk sbin pci_compliance_resolver --enable all command
    I believe all listed services were secured :
    • panel - Applying security changes for sw-cp-server (nginx for Plesk).
    • apache - Applying security changes for Apache server.
    • courier - Applying security changes for Courier IMAP.
    • dovecot - Applying security changes for Dovecot.
    • qmail - Applying security changes for qmail.
    • postfix - Applying security changes for Postfix MTA.
    • proftpd - Applying security changes for ProFTPd.
    But I'm not sure what the command does exactly and what file to look at to double check. (For Apache, it doesn't matter, since we don't use it).
    For instance, if I look at /etc/dovecot/conf.d/ file changed date, 10-plesk-security.conf content is :
    ## Default values for security settings tunable by
    ## pci_compliance_resolver Plesk utility.
    # PLEASE DON'T EDIT ANYTHING IN THIS FILE! ANY CHANGES WILL BE LOST ON UPGRADE.
    # Disable LOGIN command and all other plaintext authentications unless
    # SSL/TLS is used (LOGINDISABLED capability). Note that if the remote IP
    # matches the local IP (ie. you're connecting from the same computer), the
    # connection is considered secure and plaintext authentication is allowed.
    # See also ssl=required setting.
    disable_plaintext_auth = no
    Is that correct ?
    Anyhow, I'm happy to see an A+ PCI-DSS compliance on Immuniweb and an A+ on ssllabs for the domain :443
    Only concerns are :
    IMPA & POP3 getting an A- (The certificate doesn't match hostname)
    SMTP SSL / 465 getting a B- (The certificate doesn't match hostname)
    Looking at certificates :
    Root CA  DST Root CA X3 is self signed (expires in 683 days)
    Intermediate CALet's Encrypt Authority X3 (expires in 486 days)
    Server certificate : server.domain.tld (expires in 31 days)
    How can I fix that please ?
    Jeff Carter
    With Plesk Obsidian 18.0.29 this appears to be fixed.
    Farhad Pez
    I added via Plesk graphical interface " /usr/local/psa/bin/server_pref -u -ssl-protocols 'TLSv1.1 TLSv1.2' " but the problem with my Paypal in Wordpress is not solved.
    I reverie this error in Dashboard:
    WARNING: You may no longer be able to accept PayPal payments after June 2018!
    It looks like your server does not support TLS 1.2. As of June 2018, PayPal is dropping support for TLS 1.1 and your payments may no longer function properly. It is critically important that you upgrade your server to support TLS 1.2 as soon as possible. For more information, contact your web hosting provider and ask them to support TLS 1.2. More information is available in PayPal’s TLS 1.2 and HTTP/1.1 Upgrade Documentation.
    If you have made the necessary changes, and still see this message, you can check again.
    I use: CentOS Linux 7.7.1908 (Core)‬, Plesk Onyx - Version 17.8.11 Update #73
    Thank you
    waemmanuel
    Hi, all
    What is the recommended way of updating SSL/TLS protocols and ciphers on older versions of Plesk, specifically  version 9.5.4 on centos
    It seems this is done by updating file and the utility plesk bin server_pref -u -ssl-protocols does not work on this version.
    Ivan Postnikov
    Hello @Dr. Koonz, thank you for the notice, the article will be reviewed and updated.
    Aristeidis Vlachopanos
    Hello, I am using the above commands in my linux server running
    OS ‪Debian 6.0.10‬
    Plesk version 12.5.30 Update #24
    and I am getting
    plesk bin server_pref -u -ssl-protocols "TLSv1.1 TLSv1.2"
    Warning: Current locale is unusable. Using 'C' instead.
    [2018-08-21 17:26:21] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/sslmng' '--protocols' 'TLSv1.1 TLSv1.2'] with exit code [1]
    sslmng failed: WARNING:Ignoring unsuppored protocol TLSv1.1
    WARNING:Ignoring unsuppored protocol TLSv1.2
    ERROR:No supported protocols supplied
    exit status 1
    how do I resolve this?
    Jonathan Burrows (Edited )
    I'm having an awful time with a rebuilt Fasthosts server. It's running CentOS 6.8 and Plesk 12.
    Browsers are throwing up errors like
    Error code: SSL_ERROR_UNSUPPORTED_VERSION
    I run the above command and I get the following.
    # plesk bin server_pref -u -ssl-protocols 'TLSv1.2'
    Unrecognized option: '-ssl-protocols'
    Really struggling to make any sense of any search out there
    dufresne
    Hello,
    Thanks for this tutorial.
    I've done it, it works perfectly.
    But the ssl labs test report that : TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
    AND : TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
    Are weak.
    Could you update the cipher list on the tutorial without those ciphers ?
    Thanks
    Lev Iurev
    @lenala Please check the article https://support.plesk.com/hc/en-us/articles/115001446174-How-to-secure-a-Plesk-mail-server-with-different-SSL-certificates-SNI-support-
    This could be reached on Plesk Obsidian only.
    Anton Maslov
    Hi waemmanuel you may try to change settings by editing services configuration files directly like for example /etc/httpd/conf.d/ssl.conf for Apache. Thought the best option still would be just to migrate to up-to-date OS and Plesk.
    Wolfgang Reidlinger (Edited )
    This is my system:
    Product version: Plesk Onyx 17.8.11 Update #35
    Update date: 2018/12/22 17:07
    Build date: 2018/12/12 07:22
    OS version: Ubuntu 18.04
    Revision: a3b2193c4694c7c9adea4d6bcd5882fff19ce9ef
    Architecture: 64-bit
    Wrapper version: 1.2
    To enable TLSv1.2 server-wide and activate strong ciphers, I did the following.
    I miss Strict Transport Security (HSTS) and OCSP Stapling, but the features are quite limited. (https://docs.plesk.com/en-US/onyx/cli-linux/using-command-line-utilities/server_pref-interface-and-system-preferences.37785/)
    /usr/local/psa/bin/server_pref -u -ssl-protocols 'TLSv1.2'
    /usr/local/psa/bin/server_pref -u -ssl-ciphers 'ECDHE-RSA-AES256-GCM-SHA512:DHE-RSA-AES256-GCM-SHA512:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384'
    root@admin:~# /usr/local/psa/bin/server_pref -s | grep ssl-*
    ssl-protocols: TLSv1.2
    ssl-ciphers: ECDHE-RSA-AES256-GCM-SHA512:DHE-RSA-AES256-GCM-SHA512:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384
    Bruno SCHOULER
    Hello all
    My server is
    Version Plesk Onyx v17.5.3_build1705170317.16 os_CentOS 6
    OS
    CentOS 6.10 (Final)
    php 5.4.45
    I have problems with paypal module on prestashop. It is specified that now paypal needs TLS 1.2
    actually, TLS version is not compatible tell paypal !
    I'm not sure I can do this command in this post
    If I refer to this post, the command:  /usr/local/psa/bin/server_pref -u -ssl-protocols 'TLSv1.1 TLSv1.2'
    is supposed to add  TLS 1.1 and TLS1.2 ??? Is that Right ?
    In this post; comments says gettin,g problems : It's worth mentioning that disabling TLSv1.0 also disables Plesk Premium Antivirus.
    So my question :
    if i launch taht command, do I active both TLS1 and TLS1.2 or do I add TLS b1 and TLS 1.2 ?
    thanks for help
    Anton Maslov
    Jonathan Burrows Please upgrade first to Plesk 17.8 to be able to use these commands or you may try to edit settings manually in corresponding Apache/Nginx configuration files.
    Bob Benson
    Doesn't the SSLit Plesk extension handle this in an easier way?
    Ivan Postnikov
    Hello Heinrich Krebs
    Currently, TLS 1.3 is available for hosted websites only. TLS 1.3 support for the Plesk interface will be added later.
    After implementation the corresponding notice will be added here: https://support.plesk.com/hc/en-us/articles/360007400013
    Anzhelika Khapaknysh
    @Bob B,
    If I got you right, you are talking about TLS versions and ciphers by Mozilla settings:
    Yes, you can change settings here, but they are already predefined:
    Modern includes TLSv1.2 only;
    Intermediate includes TLSv1.2, TLSv1.1, TLSv1;
    Old includes TLSv1.2, TLSv1.1, TLSv1, SSLv3.
    waemmanuel
    Thank you, I will give that a go, I agree upgrade is the way to go. This is for a few legacy customers still to be migrated to a newer panel.
    Iain Hunneybell
    Well it seems impossible to edit my last post, I just get a lazy-load spinner endlessly spinning, so the end of the post should read...
    So maybe add on:
    AES256-GCM-SHA384
    AES128-GCM-SHA256
    Which gives a cipher line-up of:
    1. ECDHE-ECDSA-AES256-GCM-SHA384
    2. ECDHE-ECDSA-AES256-SHA384
    3. ECDHE-ECDSA-AES128-GCM-SHA256
    4. ECDHE-ECDSA-AES128-SHA256
    5. ECDHE-RSA-AES256-GCM-SHA384
    6. ECDHE-RSA-AES128-GCM-SHA256
    7. DHE-RSA-AES256-GCM-SHA384
    8. DHE-RSA-AES128-GCM-SHA256
    9. ECDHE-RSA-AES256-SHA384
    10. ECDHE-RSA-AES128-SHA256
    11. DHE-RSA-AES256-SHA256
    12. DHE-RSA-AES128-SHA256
    13. AES256-GCM-SHA384
    14. AES128-GCM-SHA256
    and an update command of:
    /usr/local/psa/bin/server_pref -u -ssl-ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:AES256-GCM-SHA384:AES128-GCM-SHA256'
    Interestingly, even though the openssl ciphers command lists ciphers 1-4 as available on the server and they are configured, SSLLabs doesn't mention them.
    SSLLabs then lists ciphers 5-8 as 'good'/in green, or rather doesn't highlight them as 'weak', and then lists 9-14 as all weak/in amber. You could of course exclude these ciphers depending on coverage you want for less capable user-agents.
    Testing with the DigiCert checker, it gives a different selection of the 14 ciphers listed, so we are clearly into the realms of what the testing tools themselves support! For reference DigiCert does't list:
    • 1-4, similar to SSLLabs
    • 7-9
    • 10-13
    Ivan Postnikov
    Hello @Wolfgang,
    Thank you for sharing your user experience.
    It may be helpful to other Pleskians.
    Iain Hunneybell (Edited )
    Very helpful post @Wolfgang, but which OS and version of OpenSSL are you running? I note you are listing SHA512 ciphers.
    I am still on CentOS 6.10 but can see a move to CentOS 8 coming if I want to support TLS1.3, however, on my current build with OpenSSL 1.0.1e-fips, the SHA512 ciphers you mention aren't available (full list of OpenSSL 1.0.1e ciphers). I suspect others are in a similar position ... although also note 1.0.1e has issues and should be updated, but that's a topic of a different thread on updating components outside of Plesk PUM (Package Update Manager).
    There's also an interesting difference in definition of high-strength ciphers. My OpenSSL is currently configured for:
    ssl-ciphers: HIGH:!aNULL:!MD5
    But a check with SSLLabs gives me only 4 good (not "WEAK") ciphers...
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
    and ranks everything else as weak, so clearly different interpretations of 'high strength' ciphers are in use ... although I trust SSLLabs to be a more current view on cipher strength ranking :-)
    Red Hat have a useful article on '4.13. Hardening TLS Configuration' which includes the following advice:
    To obtain a list of cipher suites that satisfy the recommendations outlined in Section 4.13.1, “Choosing Algorithms to Enable”, use a command similar to the following:
    openssl ciphers -v 'kEECDH+aECDSA+AES:kEECDH+AES+aRSA:kEDH+aRSA+AES' | column -t
    They note:
    The above command omits all insecure ciphers, gives preference to ephemeral elliptic curve Diffie-Hellman key exchange and ECDSA ciphers, and omits RSA key exchange (thus ensuring perfect forward secrecy). Note that this is a rather strict configuration, and it might be necessary to relax the conditions in real-world scenarios to allow for a compatibility with a broader range of clients.
    So maybe add on:
    TLS-RSA-AES256-GCM-SHA384
    TLS-RSA-AES128-GCM-SHA256
    SSLLabs flag these as 'WEAK' as these are based on RSA with no PFS (Forward Secrecy), but are maybe a reasonable 'backstop' for less capable clients.
    Note also the above command includes ciphers marked as SSLv3, e.g. ECDHE-ECDSA-AES256-SHA, so removing these gets me to a configuration of:
    /usr/local/psa/bin/server_pref -u -ssl-ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:RSA-AES256-GCM-SHA384:RSA-AES128-GCM-SHA256'
    I'd be interested for your views on this as a 'reasonable' configuration ... and still wonder where you are getting your SHA512 ciphers from :-)
    Ivan Postnikov
    Hello @Aristeidis,
    Debian 6 has reached EOL and is not supported.
    The recommended approach is to install Plesk Onyx on one of the supported OS versions (https://docs.plesk.com/release-notes/onyx/software-requirements/) and migrate the domains to the new server.
    Marko D. (Edited )
    after updating my default configuration via
    plesk bin server_pref -u -ssl-protocols 'TLSv1.2 TLSv1.3'
    shows my
    ssl-protocols: TLSv1.2 TLSv1.
    But https://www.ssllabs.com reports to me:
    Protocols
    TLS 1.3
    Yes
    TLS 1.2
    Yes
    TLS 1.1
    Yes
    TLS 1.0
    Yes
    SSL 3
    No
    SSL 2
    No
    Really confusing...
    Julian Bonpland Mignaquy (Edited )
    @Bruno
    The command you specified enables both TLSv1.1 and TLSv1.2 and the second one enabled only TLSv1.2:
    plesk bin server_pref -u -ssl-protocols 'TLSv1.1 TLSv1.2'.
    Ivan Postnikov
    Hello Marko D.
    The work on this functionality is till finished yet https://plesk.uservoice.com/forums/184549-feature-suggestions/suggestions/34609003-plesk-interface-s-web-server-support-for-tls-1-3
    This explains the unexpected behavior you've met.
    Once everything will be ready, this article will be updated: https://support.plesk.com/hc/en-us/articles/360007400013
