Is it possible to enable logging for mail in Plesk interface for a subscription?
Created:
2017-06-27 10:30:06 UTC
Modified:
2017-08-08 13:17:51 UTC
Have more questions?
Submit a request
It is not possible to separate mail logs from /var/log/maillog on a subscription levek so that mail logs are available in the interface under Subscriptions > example.com > Logs
This functionality is not supported in Plesk at the moment.
You may want to suggest new functionality in Plesk on Plesk User Voice portal: https://plesk.uservoice.com/forums/184549-feature-suggestions
You can get the information about the updates in our products in the following public sources:
https://partners.plesk.com/ - public roadmaps for partners;
http://kb.plesk.com/subscriptions/index.html - knowledge base, each product update comes with corresponding KB article;
http://kb.plesk.com/rss/?p=PLESK - RSS feeds
