Domain management is taking too much time: domain creation or suspension lasts more than 2 minutes
Created:
2017-01-02 22:25:13 UTC
Modified:
2017-08-08 13:46:18 UTC
Have more questions?
Submit a request
Domain management (suspend, or unsuspend, or activate, or create) is taking a lot of time.
The following entry can be found in panel.log when domain creation or suspension is being done:
DEBUG [extension/slave-dns-manager]
The process stuck on the DNS entries update stage in panel.log
Slave DNS server that is added in Plesk is in Not Connected status
Remove the Slave DNS server or connect it properly
