WordPress installation fails: filemng failed: filemng: Error occurred during /bin/rm command
2 comments
    Unknown User
    3. should be: # chown -R test_user:psacln /var/www/vhosts/example.com/httpdocs/*
    You forgot a space between test_user:psacln and /var/www/vhosts/example.com/httpdocs/*
    Alexandr Redikultsev
    Hi @Patrick Klarenbeek!
    Thanks so much for spotting it!
    Article was updated.
