SSH Fail2ban jail does not read /var/log/secure
Created:
2016-12-30 22:08:21 UTC
Modified:
2017-08-08 13:28:32 UTC
1
Have more questions?
Submit a request
  • Plesk Onyx for Linux
  • Fail2ban does not ban IP address after many SSH authorization attempts. Failed login attempts are correctly written to /var/log/secure but Fail2ban does not parse them to /var/log/fail2ban.log
  • SSH is configured to use password-based authentication, not key-based.
  • Every new failed login attempt logs into /var/log/secure in different time then the actual system time:
    # tail -1  /var/log/secure
    Jan  1 16:51:40 sshd[16856]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=10.10.10.10  user=root
    # date
    Sun Jan  1 18:51:43 SAST 2017
Hanged rsyslog process.
Restart rsyslog process:
# systemctl restart rsyslog.service
After that logs should be written to /var/log/secure in the actual system time:
# tail -2  /var/log/secure
Jan  1 16:54:19 sshd[16928]: PAM service(sshd) ignoring max retries; 6 > 3
Jan  1 18:54:24 sshd[16940]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=10.10.10.10  user=root
