Webmail or Websites are loading very slow or loading continuously and eventually fail with a 50x error in a web-browser: 500 Internal Server, 502 Bad Gateway, 503 Service Temporarily Unavailable, 504 Gateway Time-out.
The following message appears on the domain's Logs page (Plesk > Domains > example.com > Logs) or in the domain's error logfile
/var/www/vhosts/system/example.com/logs/error_log
directly on the server:CONFIG_TEXT: mod_fcgid: can't apply process slot for /var/www/cgi-bin/cgi_wrapper/cgi_wrapper
In some cases, the following error message may appear in domain's
proxy_error_log
file/var/www/vhosts/system/example.com/logs/proxy_error_log
:CONFIG_TEXT: [log_config:warn] [pid 30019] (32)Broken pipe: [client 203.0.113.2:51022] AH00646: Error writing to |/opt/psa/admin/sbin/pipelog 7081, referer: http://www.example.com/
The Apache FcgidMaxProcesses
, or FcgidMaxProcessesPerClass
limit has been reached.
In rare cases, the issue might appear when a client closed the connection before waiting for the server to respond.
If the client closed the connection before receiving a server's response, the issue is on the client side.
To increase FcgidMaxProcesses
and FcgidMaxProcessesPerClass
Increase the value of
FcgidMaxProcesses
andFcgidMaxProcessesPerClass
:2.1. Open the
fcgid.conf
file in any text editor. In this example we are using the vi editor:-
on CentOS/RHEL-based distributions
# vi /etc/httpd/conf.d/fcgid.conf
on Debian/Ubuntu-based distributions
# vi /etc/apache2/mods-enabled/fcgid.conf
2.2. Navigate to the directive
FcgidMaxProcesses
and increase its value. General recommendations: RAM 8GB - about 150, RAM 16GB - 300.2.3. Navigate to the directive
and increase its value to 10, or 15.2.4. Save the changes and close the file.
Check if there are other files in the Apache configuration directory that can override parameters in
fcgid.conf
. If files other than fcgid.conf are found, increase theFcgidMaxProcesses
limit in these files too.-
on CentOS/RHEL-based distributions:
# grep -irE 'FcgidMaxProcesses|FcgidMaxProcessesPerClass' /etc/httpd/conf.d/
on Debian/Ubuntu-based distributions:
# grep -irE 'FcgidMaxProcesses|FcgidMaxProcessesPerClass' /etc/apache2/
Restart Apache to apply the changes:
# service httpd restart
# service apache2 restart
Check websites' status.
If the solution above did not help, switch faulty domains to nginx with PHP-FPM:
5.1. In Plesk go to at Domains > example.com > PHP Settings and run PHP as FPM application served by nginx.
5.2. Go to domain's Apache & nginx Settings:
- Proxy mode
- Smart static files processing
- Serve static files directly by nginx
2 comments
did you tested that solution...??
after the restart of the apache the value changes back to the original value
@TechTown GmbH
Hello! I have just tested the solution on my Plesk Onyx (CentOS 7)
Please describe a scenario when this setting was changed to original value.
