Attempt to access PostgreSQL database using network connection to
localhost:5432
fails:CONFIG_TEXT: psql: FATAL: Ident authentication failed for user "pgdb1_user1"
Plesk websites installed with Ruby application show the following error:
CONFIG_TEXT: 500 Internal Server Error
If you are the administrator of this website, then please read this web application's log file and/or the web server's log file to find out what went wrong.
PostgreSQL is configured to authenticate network connections using ident service, which is deprecated.
Change authentication configuration of host type from ident to password in
pg_hba.conf
file./var/lib/pgsql/data/pg_hba.conf
on RedHat-based systems/var/lib/postgresql/9.1/main/pg_hba.conf
on Debian-based systemsBEFORE:
CONFIG_TEXT: host all all 127.0.0.1/32 ident
host all all ::1/128 identAFTER:
CONFIG_TEXT: host all all 127.0.0.1/32 password
host all all ::1/128 password -
(Optional step) Create new line in same format for any external host:
CONFIG_TEXT: host all all 203.0.113.2/32 password
Restart PostgreSQL service to apply changes:
# service postgresql restart
