If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
 How to enable redirection from HTTP to HTTPS for a domain in Plesk
23 comments
    Renan Genova Ferreira
    Hello, Chris!
    Should be done under  "Additional directives for HTTP" - and the redirect should work for those.
    Thanks
    lenala (Edited )
    Why webmail is not redirected to HTTPS ?
    What should we add in order to redirect from HTTP to HTTPS://webmail.domain.tld ?
    (OFC, webmail is secured, before it come to your mind asking if it is).
    Chris
    Hello Renan, thanks for the information. As i use also Nginx as Reverse Proxy, do i additionally have to copy also this code to the nginx directives:
    if ($ssl_protocol = "") {
    rewrite ^/(.*) https://$server_name/$1 permanent;
    Or is the additional nginx code just needed, when nginx only webserver is used without apache?
    Thx
    Chris
    Alexandr Tumanov
    @Marco, this is a custom scenario that is not covered by this article. Plesk does not provide such possibility however, the instruction can be found somewhere in google, I guess.
    Richard Parsons
    Thank you for the suggested edit to the web.config file... I'm curious to know why HTTPS access appears to have stopped working on 2 July for no apparent reason?
    The webstats show the website to be accessible on 1 July but nothing until today when I edited web.config file... I'm still not sure that the issue is resolved because the link to the stats webpage will still not show the HTTPS version which has to be accessed manually by pasting the full HTTPS URL...
    Ioan (Edited )
    How to enable SSL for both www and non-www domain address.
    If is used with www - https://www.example.com - Chrome indicate that the site is secure: Certificate Valid, Cookies 0 in use.
    If is used without www - https://example.com - Chrome indicate that the site is NOT secure: Certificate Valid, Cookies 6 in use.
    When accessing Plesk panel using https://www.example.com:8443 or https://example.com:8443, both Chrome and IE shows not secure website.
    Marco Marsala
    What if someone wants to disable HTTP access completely, rather than redirecting?
    In other words, http://www.example.com should be unavailable, while https://www.example.com should.
    Ivan Postnikov
    Hello Richard Parsons
    I can see no Plesk updates published on the 1st of July.
    Domain and Plesk logs have to be inspected to understand what happened on the server. Depending on where Plesk license was purchased you may submit a support request directly to us or to Plesk partner, from which the license was purchased.
    Sebastien MILHAC
    Thank you Anton for your feedback.
    I paste it like this but there is no https automatic redirection when I go on http://mydomain...
    how should I paste exactly ?
    Thanks
    Sébastien
    <IfModule mod_rewrite.c>
    RewriteEngine on
    RewriteCond %{REQUEST_FILENAME} !favicon.ico$
    RewriteRule ^(.*)$ public/?a=$1 [L]
    RewriteCond %{HTTPS} !=on
    RewriteRule ^(.*)$ https://%{HTTP_HOST}/$1 [R,QSA]
    </IfModule>
    Sebastien MILHAC (Edited )
    Hello. I'm trying to enable https via .htaccess file (2 first solutions not possible for me) but mine already contents :
    RewriteEngine on
    </IfModule>
    How should I update it ?
    Thanks a lot
    Sebastien
    Chris
    Hello,
    I have installed WordPress in a subdirectory /wp .
    Do I have to copy the code for Apache:
    RewriteEngine on
    RewriteRule ^(.*)$ https://%{HTTP_HOST}$1 [R,QSA]
    </IfModule>
    Just under http or also under https apache directives?
    As I have a Subdirectory Install /wp do I have to change the Rewrite Rule for Apache or the Nginx Rewrite Code (URL) ? Are the 2 Codes redirecting all Versions http://, http://www, and https://www. to https://domain.com?
    Thank You
    Bob Benson
    I've noticed that if I enable redirect using the first set of recommended instructions (Enabling HTTPS redirection in domain settings in Plesk), that it locks the subscription from syncing (undesired).
    Then, if I "unlock and resync", the checkmark for "Permanent SEO-safe 301 redirect from HTTP to HTTPS" is removed, but the redirection appears to silently remain.
    Is this a bug?
    Pradip Bade (Edited )
    I've been facing this problem when hosted the website.
    I cannot disable Permanent 'SEO-safe 301 redirect from HTTP to HTTPS'
    I don't have any SSL certificate right now, so i want to disable this, but there's no option for me to disable this feature.
    My service provider says "Please check with your developer to use https in your website to fix this issue".
    But it's a testing website, so i dont think i need HTTPS right now.
    Please help me
    Yulia Plokhotnikova
    @Bob B
    Hello,
    The situation can be reproduced when the subscription's service plan has "Permanent SEO-safe 301 redirect from HTTP to HTTPS" option disabled in Hosting Parameters. This way a subscription indeed gets into a Locked status which is correct according to the Plesk logic: you customized the subscription adding an option that is missing in the service plan. To prevent subscription from locking, add "Permanent SEO-safe 301 redirect from HTTP to HTTPS" option on a service plan level.
    The fact that the HTTP->HTTPS redirection still remains after you click "unlock and resync" means that the data has been cached in your browser. Clear browser cache or try different browser. Also make sure you manually enter http://yoursitename instead of clicking "Open in web" in Plesk since "Open in web" option opens site over HTTPS.
    Anton Maslov
    Sebastien MILHAC it is ok to place both to .htaccess - keep your entries and paste example from article below them.
    Ivan Postnikov (Edited )
    Hello Pradip Bade
    Looks like you don't have admin access to Plesk. These permissions are adjusted in the Service Plan. So, for you it's required to contact the service provider, who provides hosting.
    As redirect to HTTPS is already enabled in Plesk you won't be able to disable it via site code.
    Chris Wong
    As Nginx is used, Nginx directives are also required.
    Bob Benson
    @Yulia Plokhotnikova,
    Thanks for your reply.
    In my opinion, that's unfortunate logic.  The option to redirect HTTP to HTTPS should be left to each end user customer, without allowing everything else controlled by "Hosting Parameters" in the service plan.
    Best Regards,
    Bob
    Anton Maslov
    Please try as below:
    RewriteEngine on
    RewriteRule ^(.*)$ public/?a=$1 [NC]
    RewriteRule ^(.*)$ https://%{HTTP_HOST}/$1  [L]
    </IfModule>
    Anzhelika Khapaknysh
    @Bob B,
    I wasn't able to reproduce the described behavior neither on Plesk Onyx 17.8 nor on the latest Plesk Obsidian microupdate.
    If the issue is still reproducible on your server, please submit the request to our Technical Support Team so they can check the issue thoroughly.
    Ivan Postnikov
    Hello @loan,
    Please, make sure that the certificate includes example.com or *.example.com.
    For example, when using Let's Encrypt extension, both example.com and www.example.com will be secured:
    To secure Plesk login page you need to additionally apply the following instruction:
    https://support.plesk.com/hc/en-us/articles/213954265-How-to-secure-Plesk-login-page-URL-with-SSL-certificate
    Hello Bob Benson
    Thank you for the feedback.
    Feel free to create a feature suggestion about it at our User-voice portal
    Popular suggestions are likely to be implemented.
    For now, please, follow recommendations from my colleagues.
    Bob Benson
    @Anzhelika Khapaknysh,
    In my case, the permission "Hosting settings management" is usually disabled, in the hosting plan.  In this case, it seems enabling "HTTPS redirection" locks the subscription.
    Best Regards,
    Bob
