- Plesk for Windows
When renaming a domain from old-example.com to example.com, the following error appears in Plesk:
PLESK_ERROR: Error: Site old.example.com does not exist
at (WebServerManager::renameHosting line 3083)
at renameHosting(old.example.com, example.com)(WebServerManager::renameHosting line 3122)
at execute console command --rename-vhost(vconsoleapp::start line 122)
at execute "C:\Program Files (x86)\Parallels\Plesk\admin\bin64\websrvmng" --rename-vhost "--vhost-config=tmp2811.tmp" "--old-name=old-example.com"(vconsoleapp::run line 139) (Error code 1)OR
PLESK_ERROR: Error: websrvmng failed: Site old-example.com doesn't exist
at (WebServerMap::get line 189)
at startHosting(old-example.com)(WebServerAdapter::startHosting line 772)
at execute console command --start-vhost(vconsoleapp::start line 122)
at execute "C:\Program Files (x86)\Parallels\Plesk\admin\bin64\websrvmng" --start-vhost "--vhost-name=old-example.com"(vconsoleapp::run line 139)
(Error code 1) -
The "plesk repair web" utility fails with the error message below:
C:\> plesk repair web old-example.com
Repairing web server configuration
Repairing web server configuration for the domain
old-example.com ............................................... [FAILED]
- Filename:
\?\C:\Inetpub\vhosts\old-example.com\httpdocs\web.config
Line number: 14
Error: Configuration file is not well-formed XML
In module
Exception type: System.Runtime.InteropServices.COMException
There is no old-example.com site in IIS Manager > SERVERNAME > Sites.
In some cases, the folder of the domain old-example.com is already renamed to example.com in %plesk_vhosts%.
Incorrect website configuration in IIS.
The web-config file of the domain old-example.com contains invalid-records.
Connect to a Plesk server via RDP.
If the folder example.com already exists in %plesk_vhosts%, rename it to old-example.com.
Rename the file web.config to web-config.orig of the domain old-example.com at %plesk_vhosts%.
Start Internet Information Services (IIS) Manager at Windows Start > All Programs > Administrative Tools.
In IIS Manager, expand SERVERNAME > Sites > right-click on example.com > click Remove.
Start a command prompt as an Administrator and repair the website old-example.com:
In some cases, the repair process may fail with one of the following error messages:
Error 1:
C:\> Repairing web server configuration for the domain example.com [FAILED]
- A specified logon session does not exist. It may already have
been terminated. (Exception from HRESULT: 0x80070520)In this case, go to Plesk > Domains > example.com > Hosting Settings > select Default Certificate from the drop-down list and click OK. Retry repair.
Error 2:
- Filename:
\?\D:\INETPUB\VHOSTS\example.com\httpdocs\web.config
Line number: 14
Error: Configuration file is not well-formed XMLIn this case, rename the file web.config to web-config.orig of the domain old-example.com in %plesk_vhosts%.
Repair password-protected directories:
C:\> "%plesk_cli%\repair.exe" --synchronize-protected-directories-storage
Log in to Plesk and rename the domain.
