How to create custom Apache and nginx configuration files for all domains in Plesk
6 comments
    Raoul STANISLAS
    Hello
    it's very easy to create customized nginx configuration files
    But where do we find the variables to use custom PHP settings ?
    In file /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php
    <?php if (!empty($VAR->domain->physicalHosting->proxySettings['nginxClientMaxBodySize'])): ?>
    client_max_body_size <?php echo $VAR->domain->physicalHosting->proxySettings['nginxClientMaxBodySize'] ?>;
    <?php endif ?>
    <?php if ($VAR->domain->physicalHosting->scriptTimeout): ?>
    proxy_read_timeout <?php echo min($VAR->domain->physicalHosting->scriptTimeout, 2147483) ?>;
    <?php endif ?>
    $VAR->domain->physicalHosting->scriptTimeout is value for field max_execution_time
    What is $VAR->domain->physicalHosting->??? to use value to field post_max_size or upload_max_filesize ?
    Thanks
    Francisco Garcia
    Hi Raoul STANISLAS,
    These 3 settings are set in Plesk > Domains > example.com > PHP Settings.
    Also, can be done massively with: How to change PHP settings for one domain or all domain in Plesk using command line?
    Raoul STANISLAS
    Hi Francisco Garcia,
    No commande line, I want to customize by domain and want to use a value in PHP settings.
    I don't want to use a global value like here.
    There are no "proxySettings[nginxClientMaxBodySize]" custom field in Plesk > Domains > example.com > Apache & Nginx Settings, so I want to use Plesk > Domains > example.com > PHP Settings > upload_max_filesize in my file /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php
    Francisco Garcia
    Hi Raoul STANISLAS,
    One thing is completely different from the other, you're talking about PHP Settings, but then now you talk about Nginx MaxBodySize.
    I know one is related to the other, as if one increases, the other should also increase, but are completely different settings.
    For Nginx, this might be interesting for you https://support.plesk.com/hc/en-us/articles/213914565
    Miha Gregorš
    Hello,
    after creating custom nginx template I got this error when I want to update/upgrade Plesk from 17.8 to 18 https://support.plesk.com/hc/en-us/articles/115001394613-Plesk-error-Template-processing-failed-TemplateException.
    Is there any more elegant solution for custom global nginx configuration?
    We need this because we want to block badbots with global nginx.
    We just add those directives below in file /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php
    # Include custom.d/*.conf
    include /etc/nginx/custom.d/*.conf;
    Regards,
    Anton Maslov
    Miha Gregorš vhost templates differs depending on the version, thus it is required to recreate them after upgrade:
    1. Move out current templates
    2. Perform an upgrade
    3. After that you need to recreate custom template taking the new nginxDomainVirtualHost.php from 18 version.
    Alternative way is to use fail2ban: it has built in badbots jail, but you may adjust it if you need to ban additional bots.
