If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Does Plesk install updates for system packages automatically?
3 comments
    Leonid Gukhman
    Ehud Ziegelman
    Articles in our KB (including this one) refer to Plesk functionality, whereas updating system packages is a system administrative task that should be performed independently. As for the kernel updates, there is also a link in the article explaining the process and suggesting KernelCare as an automatic alternative.
    Ehud Ziegelman
    Article lacks info of the update itself:
    To install system package updates please use the apt-get utility. Run the command below to start the update of system packages:
    # apt-get update && apt-get upgrade
    After the installation is completed, please reboot the server via the following command at a suitable time:
    # reboot
    In addition, you can also try using KernelCare extension to be sure that a server's kernel is up-to-date. The extension allows installing kernel updates on the fly without rebooting the server.
    It is safe to update Plesk server's system packages using an operating system package manager and moreover, we recommend to keep the system up-to-date and update system packages from official repositories in case such updates are available. It allows keeping your Plesk server secured. Please refer to the following article for details: Is it safe to update Plesk server's system packages using an operating system package manager?
    Ehud Ziegelman (Edited )
    @Leonid Gukhman,
    True, however it's extremly important to point out this fact, that the article recommended actions do NOT fully cover full server update, and what are the additional stesp required to achieve such full server update. Clients do NOT care what portion of the server update is taken care on Plesk, but that they get a fully updated server.
