'Manage in SpamFiler Panel' button of SpamExperts extension does not work: credentials are not valid
Created:
2017-06-02 21:03:32 UTC
Modified:
2017-08-16 17:31:31 UTC
Have more questions?
Submit a request
  • Plesk 12.5
  • Plesk Onyx
Unable to click on Manage in SpamFiler Panel button under Plesk > Extensions > SpamExperts .
The following could be found in /var/log/plesk/panel.log :
[2017-06-03 15:24:25] INFO [extension/spamexperts-extension] Making SpamFilter API request: /api/domain/exists/domain/example.com
[2017-06-03 15:24:25] INFO [extension/spamexperts-extension] SpamFilter API response: ERROR: Supplied credential is invalid.
[2017-06-03 15:24:25] DEBUG [extension/spamexperts-extension] Modules_SpamexpertsExtension_SpamFilter_Api::checkDomain: Result: false Response: 'ERROR: Supplied credential is invalid.
Temporary issue on SpamExperts side.
Please contact Plesk Technical support using this link in order to fix the error.
