Docker container does not start on Plesk server: No chain/target/match by that name
2 comments
    Michele Negrini
    hello,
    I do not leave containers in docker, I checked the above but nothing, the container is created but remains in stopped, use plesk in cents 7 64bit on aws, what can I check?
    Konstantin Annikov (Edited )
    @Michele Negrini,
    Can you clarify, what the error appears while you starting the container from Plesk>Extensions>Docker>%Image name% (See the screenshot attached)? Is it iptables failed?
