How to create jail in Fail2ban?
4 comments
    Tufan Lbs
    hello
    Fail2ban it gives an error
    Unable to open selected jails: f2bmng failed: ERROR:__main__:[Errno 21] Is a directory: '/etc/fail2ban/jail.local'.
    Leonid Gukhman
    @Tufan Lbs
    Hi! Try cleaning duplicate system packages:
    # yum install yum-utils
    # package-cleanup --cleandupes
    In case the issue persists, please submit a request to Plesk Support.
    Tufan Lbs
    Seçilen jail'ler açılamıyor: f2bmng failed: ERROR:__main__:[Errno 21] Is a directory: '/etc/fail2ban/jail.local'.
    The problem is not solved giving the same error
    Lev Iurev
    @Tufan Lbs  please create a ticket to our support department https://support.plesk.com/hc/en-us/requests/new
