Unable to send mail: ERROR 550 - Verification failed for SRS0=HHH=TT=example.org=sender@example.com invalid sender
    It seems there is an error in this KB
    Item 5:
    # chmod 755 /usr/lib/plesk-9.0/postfix-local
    # chown popuser:popuser /usr/lib/plesk-9.0/postfix-local
    should be:
    # chmod 755 /usr/lib64/plesk-9.0/postfix-local
    # chown popuser:popuser /usr/lib64/plesk-9.0/postfix-local
    Bulat Tsydenov
    Thank you for bringing this to our attention. The article has been changed accordingly.
    Is the postfix-local for Debian 8 also usable for Ubuntu?
    Nikolay Zhmuk
    Yes, it is, patch for Debian 8 is applicable for Ubuntu 16.04
    Michel Otte (Edited )
    While it's nice to have a fix in place for 17.5.x, the micro updates of Plesk will eventually override the patched postfix-local, unless you block updates for the whole plesk-mail-pc-driver RPM package in the masin section of the /etc/yum.conf like so:
    Artyom Baranov
    @Michel Otte,
    By blocking updates you may miss some important update.
    There is another way - create a cron task that will be executed after each Daily Maintenance task to re-apply the fix.
    Oxilion (Edited )
    The compilation failed of postsrsd on CentOS/CloudLinux 7. gcc also has to be installed for this to work so make sure it's installed:
    yum install -y unzip cmake gcc
    You can add something like this to your cronjob as a way to keep updates available but reset the fix if the postfix-local is overwritten.
    diff /root/postfix-local /usr/lib64/plesk-9.0/postfix-local || (cp -f /root/postfix-local /usr/lib64/plesk-9.0/postfix-local && service postfix restart)
    Ivan Postnikov
    Thank you for sharing these hints.
    They may be useful for other Pleskians.
