Simple DNS is unavailable after Plesk upgrade
Created:
2017-05-19 23:06:13 UTC
Modified:
2017-08-10 15:11:03 UTC
Have more questions?
Submit a request
Note: This article has the reference to the issue with the fix available:
  • #PPPM-5678 "The service of SimpleDNS Plus v. 6.0.118.0 was erroneously detected as “Not Activated”."
    Fixed in:
Simple DNS Plus 6.0.118.0 becomes unavailable after Plesk upgrade to Onyx 17.0.17.
This is Plesk bug with ID #PPPM-5678 which was fixed in Plesk Onyx 17.5.3 .
Upgrade to the latest Plesk version .
As a workaround, create an empty license.xml file at the Simple DNS installation folder, for example:
C:\ProgramData\JH Software\Simple DNS Plus\license.xml
Plesk will accept the updated configuration automatically.
