Plesk Daily Maintenance Task fails: Previous Plesk installer call finished unsuccessfully
5 comments
    Mario
    We have the same problem, however, do not want to go through the full install process (again), as that will mean downtime, possible configuration loss, etc.
    What other solution can you provide?
    Thank you
    Mario
    Actually, just executed this command and the problem is fixed now: plesk repair installation
    Ivan Postnikov
    Hello @Mario,
    Thank you for sharing the experience.
    The article resolution will be reviewed.
    Thomas Friedrich
    Current problem is:
    Err:1 http://repo.mysql.com/apt/ubuntu trusty InRelease
      The following signatures were invalid: KEYEXPIRED 1550412832  KEYEXPIRED 1550412832  KEYEXPIRED 1550412832
    Nikita Nikushkin
    Hello @Thomas Friedrich,
    Looks like the cause is outdated apt-config package
    The same information and suggested resolution can be found here:
    https://bugs.mysql.com/bug.php?id=94378
