- Plesk for Windows
Website on Classic ASP fails to load with the 404 error code when .asp file is used as a default document:
404 Not Found
The requested URL was not found on this server.
In IIS Manager
Default.asp
is atop of
Default Documents
for the affected website.
Or with error:
HTTP Error 404.3 - Not Found
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
Microsoft ASP support is not enabled for the domain.
Enable ASP support for the domain in Domains > example.com > Hosting Settings > Microsoft ASP support:
