- Plesk 12.5 for Linux
Plesk Migrator does not transfer all directories under
/var/www/vhosts/example.com
Expected behavior.All the folders under
/var/www/vhosts/example.com/
should be transferred except the following:
logs, conf, statistics and other chroot directories like lib, usr, etc and similar.
Transfer these directories manually if required.
