How to check which DNS settings were updated
Created:
2016-12-18 06:40:43 UTC
Modified:
2017-08-08 13:29:40 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
Is it possible to view which DNS records were added or removed via Plesk?
It is possible to track DNS settings changes via Plesk using Action Log.However, Action Log only shows that a DNS zone was updated without mentioning what was updated.
To make Plesk show which records were added or removed, provide your suggestion for new functionality on User Voice: https://plesk.uservoice.com/forums/184549-feature-suggestions
The top-ranked suggestions are likely to be included in the next versions of Plesk. The information about the updates in our products is available in the following public sources:
http://kb.plesk.com/subscriptions/index.html - knowledge base, each product update comes with corresponding KB article;
http://kb.plesk.com/rss/?p=PLESK - RSS feeds
