Plesk and autoinstaller are working slow
Created:
2016-12-18 06:40:06 UTC
Modified:
2017-08-08 13:40:58 UTC
Have more questions?
Submit a request
  • Plesk Onyx for Linux
Plesk and autoinstaller are working slow. All resources are checked and the hardware is in good state.
It takes time to ping any address and Plesk autoinstaller downloads *.inf files slowly.
Slow nameservers are used.
Replace nameservers in /etc/resolv.conf to Google NS:
nameserver 8.8.8.8
nameserver 8.8.4.4
2 Comments
  • 0
    Avatar
    Esteban Sánchez
    Plesk and autoinstaller are working SO slow that tend to timeout.
    The answer is working.
    But, what is this needed?
    Its because we're using IP from CL ranges and backbones?
  • 0
    Avatar
    Vitaly Zhidkov
    @Esteban, check this with your hosting provider, most likely the issue is with name servers they are using
